Integration Platform Technologies: Siebel Enterprise Application Integration > Web Services > Using the Local Business Service > SOAP Document Generated by the Local Business ServiceThe following example displays the resulting SOAP document generated by the Script Example for a Local Business Service. The addition of the authHeader element to the SOAP header corresponds to the structure defined in the sample code sections that populate the SOAP header and profileHeader elements. <?xml version="1.0" encoding="UTF-8"?> xmlns:SOAP-ENV=http://schemas.xmlsoap.org/soap/envelope/ xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <authHeader xmlns:ns1="http://siebel.com/authHeaders"> <ns1:ApplicationID>Siebel</ns1:ApplicationID> |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
