Integration Platform Technologies: Siebel Enterprise Application Integration > Web Services > About EAI File Streaming > About EAI Streaming CriteriaThe following criteria are used internally to decide whether a particular request or response is streamed:
If these conditions are not met, then the plug-in does not stream the contents of the EAI request, and the request is processed as one chunk. If these conditions are not met, then the plug-in does not stream the contents of the EAI response, and the request is processed as one chunk. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
