Integration Platform Technologies: Siebel Enterprise Application Integration > Web Services > About RPC-Literal and DOC-Literal Bindings > DOC-Literal SupportWhen a SOAP DOC-literal binding is used, the SOAP envelope (the Body element) will contain the document WSDL part without any wrapper elements. The SOAP operation is determined by way of a SOAPAction HTTP header. NOTE: SOAP:Body is in the instance SOAP message, but soapbind:body is the attribute in the WSDL document. The following is a restriction for using DOC-literal-Specification R2716. A document-literal binding in a description must not have the namespace attribute specified on contained soapbind:body, soapbind:header, soapbind:headerfault, and soapbind:fault elements. Making a Web service a DOC-literal one is the same as described in Making a Web Service an RPC-Literal Web Service. When creating the new inbound service port record in the Service Ports list applet, select SOAP_DOC_LITERAL from the drop-down list in the Binding column. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
