Integration Platform Technologies: Siebel Enterprise Application Integration > DTDs for XML Gateway Business Service > Inbound DTDs for the XML Gateway Business ServiceThe following sections contain examples of DTDs representing the %methodName% response sent from the external application to the XML Gateway. Delete ResponseThe following DTD is for the Delete response: <!ELEMENT siebel-xmlext-dekete-ret EMPTY > Init ResponseThe following DTD is for the Init response: <!ELEMENT siebel-xmlext-fields-ret (support+)> <!ATTLIST support field CDATA #REQUIRED> Insert ResponseThe following DTD is for the Insert response: <!ELEMENT siebel-xmlext-preinsert-ret (row)> <!ATTLIST value field CDATA #REQUIRED > PreInsert ResponseThe following DTD is for the PreInsert response: <!ELEMENT siebel-xmlext-preinsert-ret (row)> <!ATTLIST value field CDATA #REQUIRED > Query ResponseThe following DTD is for the Query response: <!ELEMENT siebel-xmlext-query-ret (row*)> <!ATTLIST value field CDATA #REQUIRED > Update ResponseThe following DTD is for the Update response: |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
