Transports and Interfaces: Siebel Enterprise Application Integration > EAI HTTP Transport >
Sending and Receiving Messages with the EAI HTTP Transport
You can use the EAI HTTP Transport to send and receive messages. The following procedure illustrates how you can use EAI HTTP Transport with the SendReceive method to query employee information from the Siebel Database, send it out, echo it using the Workflow Utilities ECHO service, and send it back to the workflow to write the response back to a file.
To create a workflow to send and receive messages
  1. Create a named subsystem HTTPsendreceive_conn for subsystem HTTPSubSys using the following lines:
    HTTPLoginMethod=GET
    HTTPLoginURLTemplate="http://websrvr.example.com:16007/myapplication/login.jsp?usr=V1&psw=v2"
    HTTPLogoffMethod=GET
    HTTPLogoffURLTemplate="http://websrvr.example.com:16007/myapplication/logoff.jsp"
    HTTPRequestMethod=POST
    HTTPRequestURLTemplate="http://websrvr.example.com:16007/myapplication/data.jsp"
  2. Create a named subsystem MyEchoSubsys for subsystem EAITransportDataHandlingSubsys using the following lines:
    DispatchService="Workflow Utilities"
    DispatchMethod=ECHO
  3. In your eai.cfg file, add the following line in the [HTTP Services] section:
    MyEcho = MyEchoSubsys
  4. In Siebel Tools, set up a new workflow as follows:
    NOTE:  For details on the Business Process Designer, see Siebel Business Process Framework: Workflow Guide.
  5. Create the following process properties:
    Name
    Data Type
    In/Out
    Employee Message
    Hierarchy
    In/Out
    Employee XML
    Binary
    In/Out
    Error Code
    String
    In/Out
    Error Message
    String
    In/Out
    Object Id
    String
    In/Out
    Response
    Binary
    In/Out
  6. Retrieve the employee message using the EAI Siebel Adapter with the Query method to query the information from the database using the following input and output arguments.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    OutputIntObjectName
    Literal
    Sample Employee
    Not applicable
    Not applicable
    PrimaryRowId
    Process Property
    Not applicable
    Object Id
    String
    Property Name
    Type
    Output Argument
    Employee Message
    Output Argument
    SiebelMessage
  7. Convert the message to XML using the EAI XML Converter with the Integration Object Hierarchy to XML Document method and the following input and output arguments to convert the message.
    Input Argument
    Type
    Property Name
    Property Data Type
    SiebelMessage
    Process Property
    Employee Message
    Hierarchy
    Property Name
    Type
    Output Argument
    Employee XML
    Output Argument
    <Value>
  8. Send and receive the converted XML message using the EAI HTTP Transport with the Send and Receive Response method and the following input and output arguments.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    <Value>
    Process Property
    Not applicable
    Employee XML
    String
    ConnectionSubsystem
    Literal
    Not applicable
    Not applicable
    Property Name
    Type
    Output Argument
    Response
    Output Argument
    <Value>
  9. Write the message to the file using the EAI File Transport with the Send method and the following input arguments.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    <Value>
    Process Property
    Not applicable
    Response
    Binary
    FileName
    Literal
    C:\SendRec.txt
    Not applicable
    Not applicable
  10. Save your workflow and test it using the Workflow Simulator.
Transports and Interfaces: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
