Transports and Interfaces: Siebel Enterprise Application Integration > EAI HTTP Transport > Examples Using HTTP Request > Controlling Login Sessions with Session ModeThe session mode allows control over login sessions. In this mode you log in first and open a session. Any message can be exchanged without having to log in again until you explicitly log off. The following example shows parameters for Request and Logoff in a session mode HTTP request. Session cookies are required in a case such as this. NOTE: You enter each of the following URLs as a continuous line of code.
In these URL examples, the following parameter is used: In the example, the Any XML document represented by the entry for SWEExtData can be put into the body. This would change the sample code so that the HTTPRequestURLTemplate would read as: |
| Transports and Interfaces: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
