Transports and Interfaces: Siebel Enterprise Application Integration > EAI HTTP Transport > About Sending and Receiving Messages Through HTTPTo send and receive messages through HTTP, you set up a workflow with the SendReceive method. The Receive part of that method receives the response in an output argument of that method. You can then use the response to perform an upsert operation using an integration object and EAI Siebel Adapter, or display the response to your user. In this scenario, none of your quote integration design uses the eai.cfg or the SWSE. You are performing an outbound HTTP call and waiting for a response synchronously. You can then communicate the response to the user by displaying the returned error message in a browser alert or use the new User Interact step of the workflow to refresh the view and show any new updates to fields to the user. The User Interact step can run synchronously or asynchronously, in the local Siebel Application Object Manager or on the server. |
| Transports and Interfaces: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
