Transports and Interfaces: Siebel Enterprise Application Integration > EAI MSMQ Transport > Configuring the EAI MSMQ Transport ServersThe instructions in this topic are for configuring the EAI MSMQ Transport servers. Use a two-server setup, configured as listed in the following topic. However, you can implement a single server or multiple servers. MSMQ Primary Enterprise ControllerYou configure the MSMQ Primary Enterprise Controller with the following components:
Regional Enterprise Server and MSMQ ClientYou configure the Regional Enterprise Server and MSMQ Client with the following components:
NOTE: The MSMQ Server can reside on either the MSMQ Primary Enterprise Controller or the Regional Enterprise Server. This functionality is independent of the underlying database. You can use any supported database, including IBM DB2, DB2 for z/OS, Oracle Database, and Microsoft SQL Server. |
| Transports and Interfaces: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
