Transports and Interfaces: Siebel Enterprise Application Integration > Integrating Siebel Business Applications with Java Applications > About the Siebel Code Generator >
Invoking the Siebel Code Generator
This topic describes how to invoke the Siebel Code Generator to create JavaBeans for either a Siebel business service or a Siebel integration object.
To invoke the Siebel Code Generator
  1. Start Siebel Tools.
    NOTE:  For information about how to use Siebel Tools, see Using Siebel Tools.
  2. Select Business Service or Integration Object in the Object Explorer.
    NOTE:  If Integration Object is not present, then add it by checking Integration Object on the Object Explorer tab of the Development Tools Options window opened by selecting View, then Options.
  3. Select the desired business service or integration object.
    For example, at the right top of the Integration Object list, there is a set of three buttons: Synchronize, Generate Schema, and Generate Code.
  4. Click Generate Code.
  5. Complete the Code Generator wizard:
    1. Leave the business service as is. There is only one available, the Siebel Code Generator.
    2. Select either Java(JDB) (Java Data Bean) or Java(JCA) (Java EE Connector Architecture/Siebel Resource Adapter) for the Supported Language.
    3. Browse to select an existing folder as the output folder. Your Java code for the selected business services or integration objects is stored in subdirectories there, as explained next.
    4. Click Finish.
      The code is generated and the wizard closes, returning you to the Business Service or Integration Object form.
Transports and Interfaces: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
