Transports and Interfaces: Siebel Enterprise Application Integration > EAI DLL and EAI File Transports > About the EAI File Transport > Enabling Write Access for the EAI File TransportThe EAIFileTransportFolders parameter allows you to enable write access for the EAI File Transport for specific folders within the Siebel file system. The EAIFileTransportFolders parameter can be set at the enterprise or server level as a semicolon-separated list. By default, the Siebel temporary folder, CAUTION: Do not allow write access to the Configuring the EAIFileTransportFolders Parameter at the Enterprise LevelYou use the srvrmgr utility to configure the EAIFileTransportFolders parameter at the enterprise level. To configure the EAIFileTransportFolders parameter at the enterprise level
Configuring the EAIFileTransportFolders Parameter at the Server LevelYou use the srvrmgr utility to configure the EAIFileTransportFolders parameter at the server level. To configure the EAIFileTransportFolders parameter at the server level
Configuring the EAIFileTransportFolders Parameter in the Application Configuration FileYou add a new section to the application configuration file to configure the EAIFileTransportFolders parameter. To configure the EAIFileTransportFolders parameter in the application configuration file |
| Transports and Interfaces: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
