Transports and Interfaces: Siebel Enterprise Application Integration > EAI DLL and EAI File Transports > About the EAI File Transport > Generating Unique FilenamesWhen using the EAI File Transport, you can have the system generate unique file names for you, as needed. One way is to specify the directory name only. The other way is to include $$ in the filename. NOTE: If a directory is not specified when using the EAI XML Write to File, EAI XML Read from File, or the EAI File Transport business service, then the FileName input argument defaults to the directory where the Siebel application is running. Directory Only. To generate the unique file name, only enter the directory name. For example, instead of specifying the filename as Using $$. For generating filenames based on the $$ wildcard, specify the filename in the form NOTE: The file name generated by using $$ is not returned as the output filename property. |
| Transports and Interfaces: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
