Transports and Interfaces: Siebel Enterprise Application Integration > EAI Transports and Interfaces Overview > About Object Interfaces and EAIObject Interfaces allow integration between the Siebel application and external applications. Object Interfaces can be called by eScripts and VB or used within a workflow. The workflow can use other business services and transports as needed. Available object interface support includes Siebel Java Data Beans for integration with Java EE applications. For information, see Integrating Siebel Business Applications with Java Applications. |
Transports and Interfaces: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
