XML Reference: Siebel Enterprise Application Integration > XML Representation of Property Sets > Properly Formatted Property SetsProperty sets are used internally to represent Siebel EAI data. A property set is a logical memory structure that is used to pass the data between business services. To benefit from using the XML Converter, be sure that any code you use, such as eScript or Siebel VB, correctly represents property sets within Siebel Business Applications for the XML Converter Business Service. This includes necessary arguments and values. An example of such code is: Set Inputs = TheApplication.NewPropertySet REM Fill in Siebel Message Header Inputs.SetType "SiebelMessage" Inputs.SetProperty "MessageId", "" Inputs.SetProperty "MessageType", "Integration Object" Inputs.SetProperty "IntObjectName", "Sample Account" Set svc = theApplication.GetService("EAI XML Converter") Set XMLInputs = theApplication.NewPropertySet Set XMLOutputs = theApplication.NewPropertySet |
| XML Reference: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
