Siebel Enterprise Integration Manager Administration Guide > Exporting Data > Editing the Configuration File for Export Processing > Exporting Selected Data RowsTo export selected rows from base tables, set the export all rows parameter as follows: Specify one or more export matches expressions to define the rows you want exported in this batch. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
