Siebel Enterprise Integration Manager Administration Guide > Exporting Data > Preparing the EIM Tables for Export Processing >
Preserved Column Values
The values for the LAST_UPD and CREATED columns in the EIM tables always contain the values for the LAST_UPD and CREATED columns from the target base table. For example, if you use the EIM_CONTACT interface table to export data from the S_CONTACT and S_ADDR_PER base tables, the values of the EIM_CONTACT.LAST_UPD and EIM_CONTACT.CREATED columns contain the data from the S_CONTACT.LAST_UPD and S_CONTACT.CREATED columns, respectively.
Siebel Enterprise Integration Manager Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
