Siebel Enterprise Integration Manager Administration Guide > Importing Data > Special Considerations for Imports > Importing Marketing ResponsesIn 6.x and later versions, you need to populate the CAMP_MEDIA_ID column in the S_COMMUNICATION base table with valid values from the S_SRC_DCP base table in order for the rows to be displayed in the Response views. You also need to do this if you are upgrading from version 5.x. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
