Siebel Enterprise Integration Manager Administration Guide > Importing Data > Special Considerations for Imports >
Importing Private Contacts
Siebel applications do not support importing private contacts using EIM. The default.ifb file contains a section that sets the CON_PRIV_FLG column to a constant N to make sure that only public contacts are imported. Because EIM does not support importing private contacts, do not change the value of the PRIV_FLG column. Do not remove this section of the .IFB file either—to import contacts, you must have the CON_PRIV_FLG section in the EIM configuration file.
Siebel Enterprise Integration Manager Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
