Siebel Enterprise Integration Manager Administration Guide > Importing Data > Special Considerations for Imports > Importing File AttachmentsEIM can import file attachments in all formats, including common file types such as Word documents (.doc), Excel spreadsheets (.xls), and text files (.txt). EIM does not place a limit on the number or the total size of files that can be imported. To import file attachments into Siebel database tables
NOTE: All three file attachment columns (FILE_NAME, FILE_EXT, FILE_SRC_TYPE) must be populated in order to import file attachments. The FILE_SRC_TYPE column must be set to FILE. Although these columns can be listed as nullable in the EIM tables, the import process will return errors if you leave any of these columns as NULL. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
