Siebel Enterprise Integration Manager Administration Guide > Importing Data > Special Considerations for Imports > Importing Exported Rows Into Target and Secondary TablesIf user keys from the secondary tables are made up of foreign keys referencing the target table and additional user keys of nonrequired columns, note that:
To avoid this problem, after exporting the target and secondary base tables rows, you should split the secondary table rows out from the exported batch into another batch, and then import the target and secondary table rows separately. |
Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
