 Siebel Enterprise Integration Manager Administration Guide > Siebel Enterprise Integration Manager: an Overview > EIM Functions >
Export Data from Siebel Base Tables
The data contained within a Siebel application is available for transfer to non-Siebel applications by using EIM. When implementing a non-Siebel application, you can export data from the Siebel database tables for use by that application. For example, you can export employee information to a corporate sales commission application. Refer to Exporting Data for a detailed discussion of the export function.
