Siebel Enterprise Integration Manager Administration Guide > Siebel Enterprise Integration Manager: an Overview > EIM Functions > Merge Data in Siebel Base TablesIn response to such external events as corporate mergers, you can merge two or more database rows into a single row. For example, you might merge the Frame, Inc. account information into the Adobe Corp. account. Refer to Merging Data for a detailed discussion of the merge function. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
