Siebel Enterprise Integration Manager Administration Guide > Running EIM > Preparing to Run an EIM ProcessYou can run an EIM process (import, export, delete, or merge) once you have:
You can start an EIM process by running a server task for the Enterprise Integration Manager component. You can run the server task using either the GUI or the command-line interface. For more information on running server tasks, see Siebel System Administration Guide. |
Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
