Siebel Enterprise Integration Manager Administration Guide > Siebel EIM Tables > EIM Table and Column Mappings > Creating New EIM Table Mappings to Existing Base TablesYou can create new EIM table mappings from an EIM table into a base table if either of the following conditions is true:
For example, you could create a new column in EIM_ACCNT_DTL and map this either to a new extension column in S_ORG_EXT or to an existing column in the extension table S_ORG_EXT_X. These mappings are defined using Siebel Tools. If you create an extension column to a base table, then run the EIM Table Mapping Wizard, the Wizard creates the following mappings:
In general, manually creating mappings to an existing Siebel base column in Siebel Tools is not supported. For further information, contact your Oracle sales representative for Oracle Advanced Customer Services to request assistance from Oracle's Application Expert Services |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
