Siebel Enterprise Integration Manager Administration Guide > Siebel EIM Tables > EIM Table and Column Mappings > Generating EIM Table Mapping ReportsYou can view and produce reports on any and all EIM tables in your repository, or query select EIM tables, including EIM tables that you have added. CAUTION: In the following procedure, unless you query for specific EIM tables, the default action is to print every EIM table in the repository. Because outputting a report for every EIM table takes a significant amount of time to prepare and print, it is recommended that you perform a query prior to submitting your report request. NOTE: To generate and print EIM table mapping reports, you need to have a running instance of Oracle BI Publisher server. For more information, see Siebel Reports Guide. The Siebel Bookshelf is available on Oracle Technology Network (OTN) and Oracle E-Delivery. It might also be installed locally on your intranet or on a network location. To generate a report for a specific EIM interface table
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
