Siebel Enterprise Integration Manager Administration Guide > Siebel EIM Tables > EIM Table ColumnsRunning EIM is an iterative process, with each step accomplishing specific tasks and moving toward successful completion of the entire process. To process on a row-by-row basis, EIM uses several columns common to every EIM table. These columns are described in this section. Several columns are mandatory. Others are conditionally mandatory, depending on the conditions of your import. To determine mandatory columns, use Siebel Tools to view each column in an EIM table and the EIM table's target base table columns. By following the recommended import sequence, you make sure that the appropriate data dependencies are established. NOTE: For import and merge processes, you must populate the ROW_ID, IF_ROW_STAT, and IF_ROW_BATCH_NUM columns in the EIM tables. This also must be done for delete processes when you run DELETE EXACT. For merge processes, you also need to populate the IF_ROW_MERGE_ID column. Do not populate these required columns with spaces because a space does not equal a NULL value. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
