Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > EIM Import Process Examples > Visibility of Fields: Example of Importing EmployeesThis example is specific to Siebel Industry Applications. This example provides a sample .IFB file for importing employees. The employee visibility depends on S_CONTACT_BU to resolve the organization, S_POSTN_CON for the position, S_PER_RESP for responsibility, and S_PARTY_PER for the relationship between the S_PARTY and S_CONTACT. ONLY BASE TABLES = S_PARTY, S_CONTACT, S_EMP_PER, S_PARTY_PER, S_PER_RESP, S_USER DEFAULT COLUMN = CON_ACTIVE_FLG, "Y" DEFAULT COLUMN = CON_DISACLEANSEFLG, "N" DEFAULT COLUMN = CON_EMAILSRUPD_FLG, "N" DEFAULT COLUMN = CON_DISPIMGAUTHFLG, "N" DEFAULT COLUMN = CON_EMP_FLG, "Y" DEFAULT COLUMN = CON_PO_PAY_FLG, "N" DEFAULT COLUMN = CON_PRIV_FLG, "N" DEFAULT COLUMN = CON_PROSPECT_FLG, "N" DEFAULT COLUMN = CON_PTSHPCONTACTFL, "N" DEFAULT COLUMN = CON_PTSHPKEYCONFLG, "N" DEFAULT COLUMN = CON_SENDSURVEY_FLG, "N" DEFAULT COLUMN = CON_SUPPRESSEMAILF, "N" DEFAULT COLUMN = CON_SUPPRESSFAXFLG, "N" DEFAULT COLUMN = CON_COURT_PAY_FLG, "N" DEFAULT COLUMN = CON_INVSTGTR_FLG, "N" DEFAULT COLUMN = CON_SPEAKER_FLG, "N" DEFAULT COLUMN = CON_SUSPECT_FLG, "N" DEFAULT COLUMN = ACCEPT_SR_ASGN_FLG, "N" DEFAULT COLUMN = CNTRCTR_FLG, "N" DEFAULT COLUMN = INT_NEWS_APPR_FLG, "N" DEFAULT COLUMN = EMP_CPFINALAPPRFLG, "N" DEFAULT COLUMN = STORE_BUDGET_FLG, "N" DEFAULT COLUMN = STORE_FORECAST_FLG, "N" |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
