 Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > EIM Import Process Examples >
Visibility of Fields: Example of Importing Assets
To make asset records visible in the GUI, populate the following tables and columns.  S_ASSET
      PR_POSTN_ID,
      ALT_FUEL_FLG,
      CAUTION_FLG,
      INTEGRATION_ID,
      ASSET_VAL_EXCH_DT,
      REGISTERED_DT,
      CUTOFF_FLG,
      ASSET_VAL_CURCY_CD,
      BU_ID,
      ASSET_NUM,
      ROOT_ASSET_ID,
      QTY,
      INSTALL_DT,
      BASE_CURRENCY_CD,
      PROD_ID,
      CUSTOMIZABLE_FLG,
      PR_EMP_ID
S_ASSET_POSTN
      ASGN_MANL_FLG,
      ASSET_ID,
      POSITION_ID,
      ASGN_SYS_FLG,
      ASGN_DNRM_FLG
S_ASSET_EMP
      ASSET_ID,
      EMP_ID
S_ASSET_BU
      ASSET_ID,
      BU_ID
