Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > Other Examples > Foreign Key Column Values: NO MATCH ROW ID versus NULL versus a Valid ROW_IDThere are three possible values that EIM can define for primary columns (foreign key columns) when it processes a batch: NO MATCH ROW ID. EIM sets the foreign key columns to NO MATCH ROW ID if the primary value cannot be found when EIM processes Step 10. EIM does this because the primary key is missing in the linked table. NOTE: The following are special considerations regarding NO MATCH ROW ID: NULL. If the foreign key columns allow a NULL value in the parent table, EIM carries the NULL value. A valid ROW_ID. If a valid ROW_ID is not defined, EIM uses the value in the primary column to determine the ROW_ID. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
