Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > Other Examples > Example of Implementing a Multi-Organization HierarchyIf you use multi-org, this means that a single record is shared across multiple organizations. For overview information on multi-org, see the section on access control in Siebel Security Guide. In this example, you are adding a new organization to convert a single-org to a multi-org. The process of converting a single-org to a multi-org involves adding the additional organization and its related structure, adding positions, and then associating the data to the new organization. NOTE: Some data, such as Accounts, has a many-to-many relationship to organizations, while other data, such as Contacts and Service Requests do not. To convert from single-org to multi-org
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
