Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > EIM Import Process Examples > Example of Updating Columns When There Are Two Non-Target Base Tables Mapped to One EIM TableIf there are two non-target base tables mapped to one EIM table and one of the non-target base tables has a foreign key pointing to the other one, the data in the same row of the EIM table cannot be inserted into these two tables in one batch or one session. In cases like this, run EIM twice. The reason is that in Step 4, the non-target parent base table is queried to resolve the foreign key of the non-target child base table, but the new row in the parent table has not been inserted. Take for example, the EIM_CONTACT mapping in 7.5 Siebel Industry Applications. You cannot insert the data in one EIM_CONTACT row into S_PARTY, S_CONTACT, S_ADDR_PER, and S_CON_ADDR simultaneously, because the foreign key of the non-target child base table S_CON_ADDR is pointing to the non-target parent table S_ADDR_PER. In the first run, a new row will be created in S_PARTY, S_CONTACT, S_ADDR_PER. In the second run, a new row will be inserted in S_CON_ADDR. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
