Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > EIM Import Process Examples > Visibility of Fields: Example of Importing Party ObjectsLoading of party objects affects visibility of fields. You should be aware that, in most cases, an organization table should be populated along with the party object table. For example, when a user clicks the Account field to open the MVG applet in the Contact form applet, the Account field disappears and returns to a null value after the EIM process is run. This is because there is an association between Contacts and Accounts that is stored in the intersection table S_PARTY_PER. So to establish this relationship, you should fill in the columns for only the S_PARTY, S_CONTACT, and S_PARTY_PER table. |
| Siebel Enterprise Integration Manager Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
