Siebel Energy Guide > Technical Reference for the Price Comparison Feature > SIS OM Pricing Calculator Business Service > Convert PC Input to PC Quote MethodThe answers from a SmartScript session are taken as the Pricing Calculator input and are converted into a Competitor Quote. Multiple quotes are created as appropriate by using the SmartScript answers. This method is part of SIS OM Pricing Calculator Business Service. Arguments[out] List of SIS OM Quote integration object instances that are used to store the utility billing information provided by a prospective customer. (Required) [in] Name of the opportunity object under which the generated PC Comparison quotes is stored. (Required) [in] ID of the opportunity object under which the generated PC Comparison quotes is stored. (Required) [in] RunId of the SmartScript session in which the answers are stored. This value typically is a process property that is set internally when the SmartScript session is finished. (Required) ReturnsList of SIS OM Quote integration object instances that are used to store the utility billing information provided by a prospective customer. Related Topic |
| Siebel Energy Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
