Siebel Energy Guide > Multi-Site Quotes in Siebel Energy > Process of Creating Multi-Site Quote Revisions (End User) > Creating Records for Multi-Site Quote RevisionsYou can create a record for a multi-site quote revision by copying a source multi-site quote. The revision inherits the field data for site characteristics, product groups, and billing groups in the source multi-site quote. However, the field data in the revision is similar to (but not identical to) the field data in the source multi-site quote. In the revision, you can change the information that is applicable to the contract services that you provide to the customer. For more information, see About Data Transformation in Multi-Site Quote Revisions. You can create a multi-site quote revision only for a submitted multi-site quote. The Revise button is disabled for a multi-site quote that is not submitted. You can click the Revise button multiple times for a submitted multi-site quote. Each resulting multi-site quote revision has the same revision number (the revision number of the source multi-site quote plus 1), has a different version number (the version number of the last revision plus 1), and inherits the same field data from the source multi-site quote. You can submit only one version of a multi-site quote revision. An error message appears when you attempt to submit another version. Also, you can click the New Version button multiple times for a multi-site quote revision. Each resulting multi-site quote revision has the same revision number as the source multi-site quote, has a different version number (the version number of the last revision plus 1), and inherits the exact field data in the source multi-site revision. For more information about new versions, see Creating New Versions of Multi-Site Quotes (End User). You can delete the record for a multi-site quote revision if you have not yet submitted that multi-site revision. This task is a step in Process of Creating Multi-Site Quote Revisions (End User). To create a record for a multi-site quote revision
| Siebel Energy Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
