Siebel Energy Guide > Multi-Site Quotes in Siebel Energy > Process of Creating Multi-Site Quote Revisions (End User) > Deactivating Sites in Product Groups for Multi-Site Quote RevisionsYou deactivate sites in product groups for multi-site quote revisions when you want to cancel the services that are associated with the products in the product groups for those sites. You can deactivate these sites to cancel these services in the following situations:
When you submit the multi-site quote revision with a deactivated site, order line items to cancel the services at that site are submitted to the order-provisioning system. These order line items have a due date that is the same as the requested date for the multi-site quote revision, and these order line items have a value of Delete in the Action field. If the order-provisioning system is properly integrated with Siebel Energy, then the appropriate contract services are closed in the order-provisioning system, and the corresponding installed assets are deactivated in Siebel Energy. If you want to deactivate a site for a multi-site quote revision so that you can restart stopped services at the site, then you must submit the multi-site quote revision after you deactivate the site. Then you must create a revision of the multi-site quote revision to add the site again to the product group. The value in the Site Status field for the prior multi-site quote revision is Inactive, and the value in the Site Status field for the new multi-site quote revision is Active. Therefore, you can add the same site to the new multi-site quote revision without seeing an error message about duplicate site records. This task is a step in Process of Creating Multi-Site Quote Revisions (End User). To deactivate a site in a product group for a multi-site quote revision
| Siebel Energy Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
