Siebel Energy Guide > Premises in Siebel Energy >
Adding Infrastructure Information in Siebel Energy (End User)
End users can create a record containing infrastructure information that is associated with a premises through an account. To add infrastructure information to a premises
- Navigate to the Premises screen, then the Premises List view.
- Drill down on the address of the premises.
- Click the Infrastructure view tab.
The upper list displays accounts and the lower list displays infrastructure.
- In the upper list, select an account.
- In the lower Infrastructure list, add a record, and complete the necessary fields.
Some fields are described in the following table.
Attribute |
Select the attribute of the infrastructure item, such as Substation ID or Transformer Type. The value you select in the Service Type field determines the values available for selection in this field. |
Value |
Type the value of the attribute. For example, if the attribute is Voltage at Meter, then a typical value is 240 volts. |
Owner |
Select the name of the customer or account that owns the infrastructure item. |
