Siebel Energy Guide > Work Orders in Siebel Energy >
Creating a Work Order in Siebel Energy (End User)
End users can create work orders. To create a work order
- Navigate to the Work Orders screen, then the Work Order List view.
- Add a record, and complete the necessary fields in the record and the More Info form. To access more fields, click the show more button in the form.
Some fields are described in the following table.
Account |
Select the master account for the work order. The field for the account number is automatically populated when you select a value in this field. |
Last Name |
Select the name of the contact for the work order. |
Order |
Select the sales order associated with the work order. |
Provider |
Select the vendor for the work order. |
Address |
Displays the address of the account. |
