Siebel Field Service Guide > Service Activities > Process of Managing Service Activities >
Creating Service Activities (End User)
You can create activities that field service engineers must complete to respond to a service call. For information about creating an activity for a service request, see Associating Activities with Service Requests (End User).
This task is a step in Process of Managing Service Activities.
To create an activity
  1. Navigate to the Activities screen, then the Activity List view.
  2. Create a new activity record, and complete the fields as appropriate.
    Some fields are described in the following table.
    Field
    Comments
    Due
    Select the latest date and time for an activity. This field indicates contractual commitments or deadlines and is populated with the value from the Date Committed field for the service request. For more information, see Date Committed.
    This field is the same as the Latest Start field in the Schedule view of the Activities screen.
    Status
    Select the state of an activity. Values include Approved, Unassigned, and Done. Drill down on an Unscheduled value in the Status field to navigate to the Dispatch Board screen.
    Private
    Select this check box to indicate this activity is visible only to its owner.
    Repeat Frequency
    Select the interval at which to repeat the activity. Values include Daily, Weekly, Monthly, Quarterly, and Yearly. A repeated activity appears multiple times in the calendar for the field service engineer. You cannot schedule repeated activities on the Dispatch Board.
    Repeat Until
    Select the ending date for repeating the activity.
    Alarm
    Select this check box to sound a warning if the activity does not begin by the planned start date.
    Employees
    Select the names of the employees assigned to complete the activity. You can identify an employee as the primary employee.
    SR #
    Select the service request associated with the activity.
    Billable
    Select this check box to indicate the activity is billable to the customer.
    Duration
    Type the amount of time (in minutes) required to complete an activity, including breaks and travel time. Duration is the time difference between the planned start date and the planned end date for the activity. This field appears in the form only.
  3. Drill down on the Type field for a selected activity, and click the More Info view tab.
  4. Complete the fields as appropriate.
    Field
    Comments
    Private
    Select this check box to indicate the activity is visible only to its owner.
    CR #
    Select the defect number for a product associated with the activity.
    Lock Assignment
    Select this check box to indicate Assignment Manager cannot reassign the activity to an employee.
    Category
    Select a category for the activity. This field determines the type of child records that are inherited from the activity template. For more information, see Service Activity Templates and Activity Plans.
    Developers can use Siebel Tools to change the default values for the Category field. They set ASGN_USR_EXCLD_FLG to N.
    Resolution
    Select the solution code for an activity.
    Defective Tag
    Select the tag number (repair number) associated with the activity.
Siebel Field Service Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
