Siebel Field Service Guide > Siebel Advanced Contracts > Process of Managing Siebel Advanced Contracts >
Adding Terms to Agreements (End User)
You can add agreement terms to agreements in the following ways:
  • Contract administrators can create agreement term templates in the Term Templates view of the Administration - Contracts screen. For more information, see Creating Term Templates.
    Users can then add these terms to the agreement in the Terms view in the List view of the Agreements screen.
  • Users can create terms directly from the Terms view in the List view of the Agreements screen.
These terms are included in the final agreement document.
This task is a step in Process of Managing Siebel Advanced Contracts.
To add a term to an agreement
  1. Navigate to the Agreements screen, then the List view.
  2. Drill down on the Name field for a selected agreement, and click the Terms view tab.
  3. In the Terms view, complete one of the following steps:
    1. Create a new term record for a term that does not exist in the library of term templates, and complete the fields as appropriate.
      Some fields are described in the following table.
      Field
      Comments
      Section
      Type a document section number for the term (for example, 1.1, 1.2, and so on).
      Term Name
      Type a representative description for the term (for example, Term Length).
      Type
      Select the legal type of the term (for example, Standard, Non-Standard, or Special).
      Description
      Type a description of the actual term to include in the agreement.
    2. Add an existing term record to the agreement by clicking Add, selecting a term, and clicking OK.
      You can use Ctrl+Click to select multiple terms and Ctrl+A to select all terms in the list.
      NOTE:  After you insert the terms into the agreement, you can edit the terms.
Siebel Field Service Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
