Siebel Field Service Guide > Agreements and Entitlements > Roadmap for Administering Agreements > Configuring Data Maps to Copy Specified DataYou can use conditional data mapping capabilities to specify that only certain information is copied to the agreement. To accomplish this copying, you can add a source search specification to the data map. The ISS Copy Service business service then copies a source expression to a destination field. This task is a step in Roadmap for Administering Agreements. To configure a data map to copy specified data
Example: Copying Only Service Products from Orders to AgreementsThe following example uses a search specification to specify that only service products are copied from an order to an agreement. To copy only service products from orders to agreements
Asset-Based OrderingUsers can create assets from orders using asset-based ordering. When asset-based ordering is enabled in Siebel Order Management, users can use the Installed Assets view of the Accounts screen to create orders by using the existing assets for the customer. Installed assets can include both products and services. When you use the appropriate views with the automated asset-based order workflows, the time to create quotes, orders, and agreements for asset records is reduced because many tasks are automated. The user covers the assets with the service product on the order, and clicks Auto Contract in the Agreements view in the List view of the Service Orders screen. The agreement is created with only the service product for the agreement line item and the added assets as covered assets. Line items that are not related to service are not included in the agreement. |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
