Siebel Field Service Guide > Agreements and Entitlements > Roadmap for Administering Agreements > Running Charge Plans for Agreement Line Items Using WorkflowsYou can use workflows to automatically run charge plans and create charges for agreement line items. For more information, see Defining Charge Plans for Agreement Line Items (End User). You can use the FS - Generate Agreement Charge workflow and the FS - Generate All Agreement Charges workflow to set up a repeating component job to run charges. For more information, see FS - Generate Agreement Charge Workflow and FS - Generate All Agreement Charges Workflow. NOTE: It is recommended that you run the charge process on the same repeating schedule as the contract schedule for the charge plans. This task is a step in Roadmap for Administering Agreements. To run charge plans for agreement line items using a workflow
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
