Siebel Field Service Guide > Agreements and Entitlements > Process of Administering Entitlements > Defining Preventive Maintenance Plans for Entitlement TemplatesIn the Preventive Maintenance view, you can add a record for each preventive maintenance plan to include in the entitlement template. When selecting a plan from the Add Preventive Maintenance Plans dialog box, select the check box in the Active field to select a plan. Selecting a record without selecting this check box fails to select the plan. This task is a step in Process of Administering Entitlements. To define a preventive maintenance plan for an entitlement template |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
