Siebel Field Service Guide > Business Service Methods in Siebel Field Service > Business Service Methods for Preventive Maintenance > GeneratePM MethodGeneratePM generates service requests and activities for asset maintenance by using predefined triggers. The mode, end date, and sub-mode are passed as arguments to this method. Depending on the combination of the mode and sub-mode values, other arguments are needed. For example, if the value for the mode is SQL, and the value for the sub-mode is Assets&Plans, then the plan SQL and asset SQL arguments are needed. The input parameters are called when invoking from code or from a component job. For more information about the parameters for this engine, see Parameters for the Preventive Maintenance Engine. DefOrgID denotes the default organization for the created service requests and activities, and DefActOwnerId denotes the owner of the activities. |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
