Siebel Field Service Guide > Business Service Methods in Siebel Field Service > Business Service Methods for Charges > CreateExpenseEntitlementCharge MethodCreateExpenseEntitlementCharge creates the entitlement adjustment charge for an activity expense. If you do not want to charge expense adjustment, then remove the ChargeBusinessServiceMethod2 user property from the FS Expense Item business component. For more information, see Table 60. TIP: Charges can be generated even for a zero amount ($0) adjustment charge. To remove such adjustment charges from the final invoice, you can modify the charge consolidation plan. Add a consolidation rule with a Name field value of Search Spec and a Value field value of [FS Charge. Amount = 0] AND [FS Charge.Entitlement Id <> NULL]. For more information, see Creating Charge Consolidation Plans. This method is not used as part of any workflow process. Invoked FromThis method is called directly from the FS Charge List Applet - Auto Charge (in the Charges view in the Activity List view of the Activities screen). The business service is called directly from the applet class. |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
