Siebel Field Service Guide > Business Service Methods in Siebel Field Service > Business Service Methods for the Dispatch Board > UnassignActivity MethodUnassignActivity reverses the assignment of an activity in the Dispatch Board and sets the Status field for the activity to Unscheduled. If pre- or post-processing must occur on the drag-and-drop business event to support a specific business process, then you can access the arguments for this method from custom code. Invoked FromThis method is called by the FS DB Unplanned Activity List Ax Applet when a user drags an activity off the applet for the Gantt chart and drops the activity to the bottom applet in the Dispatch Board. The Drag Drop Business Service applet user property affects this method call. |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
