Siebel Field Service Guide > Business Service Methods in Siebel Field Service > Business Service Methods for Entitlements > GenerateList MethodGenerateList is a utility method that loops through the workflow. This method queries for data by using search specifications and returns a property set according to field list values. Subsequent steps in the workflow can loop through each record in the property set using the GetNextItem method. Other methods, such as VerifyPricingEntitlement, VerifyServiceEntitlement, and GetBestPricedEntitlement, can then use the resulting data. Invoked FromThis method is called by the FS - All Charge Consolidation workflow. For more information, see FS - All Charge Consolidation Workflow. UsageThe GenerateList step of the FS - Verify Entitlement Order Best Price workflow uses the GenerateList method with the following parameters:
The GenerateList step of the FS - Verify Entitlement Sales Order Best Price workflow uses the GenerateList method with the following parameters:
The GenerateQuoteLineProductList step of the FS - Verify Entitlement Quote Best Price workflow uses the GenerateList method with the following parameters:
The GetPrimaryAccountForLogin List step of the PMP Account Creation - Default workflow uses the GenerateList method with the following parameters: |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
