Siebel Field Service Guide > Cycle Counting and Replenishment > Process of Managing Cycle Counting > Recording Results of Cycle Counts (End User)The Part List view of the Cycle Counts screen displays the products to count at inventory locations. You click Generate Counts or click the menu button and select Generate Counts (All Locations) in the Cycle Counts view of the Inventory screen to create records in this view. You can also manually create records in this view. You record the results of your cycle counts in this view. This task is a step in Process of Managing Cycle Counting. To record the result of a cycle count
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
