Siebel Field Service Guide > Fulfillment > Process of Managing Fulfillment > Allocating and De-Allocating Products Manually (End User)The Actions view shows manual and automatic transactions for an order line item. When you allocate a product in an order line item, you reserve the product for the order line item. The Fulfillment and Part Locator Engines automatically create Allocate transactions. The shipping process can automatically create De-Allocate transactions. For more information about the processing logic for shipments, see About Shipping Orders. The values that you can select in the Type field of this view depend on the transactions that occurred previously. For example, you can select the De-Allocate value only after the Allocate action is performed on the order line item. This task is a step in Process of Managing Fulfillment. To manually allocate products in an order line item
After allocating products, you can manually de-allocate the products in an order line item. To manually de-allocate products in an order line item
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
