Siebel Field Service Guide > Scheduling Using Oracle Real-Time Scheduler Version 1.0 > Process of Configuring Siebel Field Service Integration to Oracle Real-Time Scheduler 1.0 > Configuring the Endpoint URLs for Web ServicesSiebel administrators configure the endpoint URLs for Web services to allow the Siebel application to communicate with Oracle Real-Time Scheduler 1.0. An endpoint URL defines the address for or connection point to a Web service. Later, they specify these endpoint URLs when configuring Oracle Fusion Middleware components to support this integration. For more information about endpoint URLs, see Siebel Field Service Integration to Oracle Real-Time Scheduler Implementation Guide and Integration Platform Technologies: Siebel Enterprise Application Integration. This task is a step in Process of Configuring Siebel Field Service Integration to Oracle Real-Time Scheduler 1.0. Configuring the Endpoint URL for Outbound Web ServicesSiebel administrators use the following procedure to configure the endpoint URL for outbound Web services. To configure the endpoint URL for outbound Web services
Configuring the Endpoint URL for Inbound Web ServicesSiebel administrators use the following procedure to configure the endpoint URL for inbound Web services. To configure the endpoint URL for inbound Web services
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
