Siebel Field Service Guide > Scheduling Using Oracle Real-Time Scheduler Version 1.0 > About Employee Administration >
Integration Changes for Employee Administration
For this integration, some of the changes and requirements for administering employees follow:
- You must populate Start Home Address and End Home Address data for employees with corresponding latitude and longitude values. For more information about associating geocodes with addresses, see Administering Addresses.
- Start Home Address and End Home Address data in the Siebel application correspond to employee logon and logoff addresses in Oracle Real-Time Scheduler 1.0. This Oracle Real-Time Scheduler 1.0 data is mandatory.
- Start Date and End Date fields are included for each employee. (For a terminated employee, set the End Date field to the last date of employment, and update Oracle Real-Time Scheduler 1.0 accordingly.)
- The following fields do not apply to this integration and are not synchronized with Oracle Real-Time Scheduler 1.0:
- Start Depot Address
- End Depot Address
- Service Role
- Cost Per Hour
- Overtime
- Start Shift From
- End Shift At
