Siebel Field Service Guide > Scheduling Using Siebel Scheduler > Defining BreaksSchedules can include any number of breaks. To define breaks, you first define a break type. For more information, see Breaks. This task is a step in Process of Administering Schedules Using Siebel Scheduler.
After you define the break type, you set the name of the break type. |
| Siebel Field Service Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
